OnBoarding overwrites custom endpoint attributes
  • 1.  OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 02:15 PM
    I currently have the enforcement policy looking for a custom attribute on the endpoint called "smart onboard." If that attribute = "yes" then the device will be redirected to OnBoard and the process works great. The customer doesn't want to onboard all smart devices at the moment.
    However, after the device is OnBoarded, the custom attributes are overwritten by the OnBoard data. Is there a way to make sure the custom attributes don't get overwritten?
  • 2.  RE: OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 02:27 PM
    Are the custom attributes named the same thing is the Onboard attributes, or are the custom attributes named something different, but are just deleted?
  • 3.  RE: OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 02:40 PM
    the attributes are not named the same thing and just get overwritten/deleted.
  • 4.  RE: OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 02:49 PM
    The ClearPass applications use the api to access policy manager which uses a destructive add. We experience this when a user connects to our dot1x network and then registers as a guest, all the custom attributes are blown away for the record.
  • 5.  RE: OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 03:09 PM
    Any way to get around this?
  • 6.  RE: OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 05:50 PM
  • 7.  RE: OnBoarding overwrites custom endpoint attributes
    OK.  Can you try to use context about these devices from another source and NOT rely on a custom attribute...or if you DO use it, have another way to distinguish a post-onboarded device.  For example the auth method = EAP-TLS or some identifier in the cert.
    To move away from using a custom attribute, try leveraging the context of the user using AD memberof or using a static host list (MAC addresses) OR use device profiler information...
    Just some initial thoughts...
  • 8.  RE: OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 05:55 PM
  • 9.  RE: OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 10:00 PM
    Thanks Cappalli I promoted it.
    Ultimately yes, AD attributes such as group membership should be used. This however is somewhat of a POC so the need to pick and choose devices based on a custom attribute is needed.
  • 10.  RE: OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 10:05 PM
    jclingan,
    The Endpoint database is indexed primarily by the mac address.  Just create a static host list of all the mac addresses that you want to indicate has this attribute.  You can then compare the calling-station-id of the device to the static host list.  If you only have one attribute, just create a static host list with all the mac addresses that have that attribute and then compare.
  • 11.  RE: OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 10:08 PM
    I understand this can be done. Is there a way to easily add all endpoints with attribute "xyz" to a static host list without having to go through and select each mach address? That's pretty cumbersome.
  • 12.  RE: OnBoarding overwrites custom endpoint attributes
    Posted Jan 02, 2014 11:13 PM
    You can import a static host list in XML form
    Here is an example of one. You just need to add the mac address in the list seperated by , and a space.
    <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <TipsContents xmlns="http://www.avendasys.com/tipsapiDefs/1.0">
      <TipsHeader exportTime="Thu Jan 02 22:09:27 CST 2014" version="6.3"/>
      <StaticHostLists>
        <StaticHostList description="" name="Aruba AP Mac" memberType="MACAddress" memberFormat="list" members="00:24:6c:cd:83:c4, 00:0b:86:82:60:97"/>
      </StaticHostLists>
    </TipsContents>
