Onboarding problems on IPHONE5 products
  • 1.  Onboarding problems on IPHONE5 products
    Posted Apr 08, 2015 02:51 PM
    Hi, we currently had an onboarding issue for IPHONE5 products running 8.2 IOS. When the correct SSID was tapped on, usually a window appear requiring a username and a password to connect to that certain SSID, but what happened to some users is instead of having two boxes, 1 for username and 1 for password, it turns out to be one box which require a PASSWORD only for that particular SSID. So the result is DENIED.
    Whoever might have the same issue before an had a solution for this please do let me know. Thank you.
    Note: A screenshot is attached
    -Lev
    Attachment(s)
    pdf
    Screenshot.pdf   61 KB 1 version
  • 2.  RE: Onboarding problems on IPHONE5 products
    Posted Apr 23, 2015 01:43 PM
    are you sure dot1x is configured for that SSID and not WPA2 or such?
