Wired Intelligent Edge
One HP smart rate technology and Cisco Mgig
  • 1.  One HP smart rate technology and Cisco Mgig
    Posted Sep 15, 2016 11:18 PM
    Hi Airheads Community,
    I would like to clarify some thing regarding wave 2:
    1. if we use Aruba AP 325 (wave 2) and connect it to non Mgig switch, would be able to maximize the 2.5 Gbps? or still 1G (2G if we aggregate) since Aruba AP 325 has no smart rate port?
    2. If we use Aruba AP 335 (wave 2 and has smart rate port), does it have intervendor compatibility with CISCO 3650 MGIG switch? I mean, would we be able to maximize wave 2 technology (2.5 Gbps) without link aggregation?
    Thank you very much!
    -Ian
  • 2.  RE: One HP smart rate technology and Cisco Mgig
    Posted Sep 15, 2016 11:25 PM
    1) 325 has dual GigE so you wouldn't be able get
    2) 335 can use multigigabit interfaces on eth0
  • 3.  RE: One HP smart rate technology and Cisco Mgig
    Posted Sep 15, 2016 11:34 PM
    Hi Capalli,
    I was a bit lost there..
    1. You mean, since AP 325 only have (2) 1G ports, even if we aggregate it, we won't be able to maximize Wave 2 (2.5 Gbps)?
    2. Yes AP 335 have smart rate ports. What I want to know is if it's compatible with CISCO 3650 multi gig switch? Would be able to achieve speed of wave 2 2.5 Gbps)?
    Thanks!
    -Ian
  • 4.  RE: One HP smart rate technology and Cisco Mgig
    Posted Sep 15, 2016 11:36 PM
    1) you can still utilize Wave 2 technology, yes.
    2) Yes
  • 5.  RE: One HP smart rate technology and Cisco Mgig
    Posted Sep 16, 2016 12:24 AM
    Thanks capalli..just want to be more sure/specific
    1. can utlilize wave 2 technology but limited up tp 2G (gig aggregation) speed only. Right?
    2. Yes - does cisco and aruba use the same technology?
  • 6.  RE: One HP smart rate technology and Cisco Mgig
    Posted Sep 16, 2016 12:27 AM
    1) yes but you'll never see speeds that high. There are too many other environmental variables.
    2) Yes, it's an open standard.
  • 7.  RE: One HP smart rate technology and Cisco Mgig
