I am currently testing the setup of a cluster of IAPs. I currently have a 105 and a 205 in the same cluster working perfectly with IPs 172.20.166.100 (master) and 172.20.166.101 slave.
I have tried to connect another 205 (same firmware) and I am getting strange error messages after booting, see below copied from console on boot:
Getting an IP address...
Jan 1 00:00:13 udhcpc[1589]: udhcpc (v0.9.9-pre) started
Jan 1 00:00:13 udhcpc[1589]: send_discover: pkt num 0, secs 0
Jan 1 00:00:13 udhcpc[1589]: Sending discover...
Jan 1 00:00:15 udhcpc[1589]: send_discover: pkt num 1, secs 512
Jan 1 00:00:15 udhcpc[1589]: Sending discover...
Jan 1 00:00:17 udhcpc[1589]: send_discover: pkt num 2, secs 1024
Jan 1 00:00:17 udhcpc[1589]: Sending discover...
Jan 1 00:00:19 udhcpc[1589]: No lease, forking to background.
Jan 1 00:00:39 udhcpc[1701]: send_discover: pkt num 0, secs 6656
Jan 1 00:00:39 udhcpc[1701]: Sending discover...
Jan 1 00:00:41 udhcpc[1701]: send_discover: pkt num 1, secs 7168
Jan 1 00:00:41 udhcpc[1701]: Sending discover...
Jan 1 00:00:43 udhcpc[1701]: send_discover: pkt num 2, secs 7680
Jan 1 00:00:43 udhcpc[1701]: Sending discover...
Jan 1 00:01:05 udhcpc[1701]: send_discover: pkt num 0, secs 13312
Jan 1 00:01:05 udhcpc[1701]: Sending discover...
Jan 1 00:01:07 udhcpc[1701]: send_discover: pkt num 1, secs 13824
Jan 1 00:01:07 udhcpc[1701]: Sending discover...
Jan 1 00:01:09 udhcpc[1701]: send_discover: pkt num 2, secs 14336
Jan 1 00:01:09 udhcpc[1701]: Sending discover...
Jan 1 00:01:31 udhcpc[1701]: send_discover: pkt num 0, secs 19968
Jan 1 00:01:31 udhcpc[1701]: Sending discover...
Jan 1 00:01:33 udhcpc[1701]: send_discover: pkt num 1, secs 20480
Jan 1 00:01:33 udhcpc[1701]: Sending discover...
Jan 1 00:01:35 udhcpc[1701]: send_discover: pkt num 2, secs 20992
Jan 1 00:01:35 udhcpc[1701]: Sending discover...
[ 110.018000] Picked up default IP a9fed91c, rand d91c
[ 115.028000] Default IP is ready
Jan 1 00:01:57 udhcpc[1701]: send_discover: pkt num 0, secs 26624
Jan 1 00:01:57 udhcpc[1701]: Sending discover...
Jan 1 00:01:59 udhcpc[1701]: send_discover: pkt num 1, secs 27136
Jan 1 00:01:59 udhcpc[1701]: Sending discover...
Jan 1 00:02:01 udhcpc[1701]: send_discover: pkt num 2, secs 27648
Jan 1 00:02:01 udhcpc[1701]: Sending discover...
DHCP timed out.
Installing default ip.
Default IP comes up.
[ 148.094000] ip_time_handler: Got ip and packets on bond0 Started master election 3579-0, rand 18
[ 148.354000] (08:02:21) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 148.354000]
DHCP timed out.
DHCP got ip address.
169.254.217.28 255.255.0.0
Compressing all files in the /etc/httpd directory...
[ 149.142000] notify cli0 to reboot system
[ 149.170000] (08:02:22) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 149.170000]
Jan 1 00:02:23 udhcpc[1701]: send_discover: pkt num 0, secs 33280
Jan 1 00:02:23 udhcpc[1701]: Sending discover...
[ 150.030000] (08:02:23) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 150.030000]
[ 150.890000] (08:02:24) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 150.890000]
Jan 1 00:02:25 udhcpc[1701]: send_discover: pkt num 1, secs 33792
Jan 1 00:02:25 udhcpc[1701]: Sending discover...
[ 151.750000] (08:02:25) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 151.750000]
[ 152.610000] (08:02:26) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 152.610000]
Jan 1 00:02:27 udhcpc[1701]: send_discover: pkt num 2, secs 34304
Jan 1 00:02:27 udhcpc[1701]: Sending discover...
[ 153.470000] (08:02:27) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 153.470000]
Done.
Starting Webserver
[ 154.330000] (08:02:28) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 154.330000]
bind: Transport endpoint is not connected
Launching NTP Client on pool.ntp.org
[ 155.276000] (08:02:30) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 155.276000]
[ 155.278000] (08:02:30) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 155.278000]
[ 155.292000] wifi0: AP type AP-205, radio 0, max_bssids 16
[ 155.368000] wifi1: AP type AP-205, radio 1, max_bssids 16
[ 155.432000] busybox used greatest stack depth: 5336 bytes left
[ 155.718000] (08:02:30) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 155.718000]
shutting down watchdog process (nanny will restart it)...
[ 156.578000] (08:02:31) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 156.578000]
<<<<< W[ 157.438000] (08:02:32) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 157.438000]
elcome to the Access Point >>>>>
Completed SW FIPS KAT test
User: [ 158.296000] (08:02:33) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 158.296000]
[ 159.156000] (08:02:34) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 159.156000]
[ 159.288000] notify cli0 to reboot system
[ 159.972000] (08:02:35) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 159.972000]
[ 160.832000] (08:02:36) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 160.832000]
[ 161.692000] (08:02:37) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 161.692000]
[ 163.482000] (08:02:39) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 163.482000]
[ 163.486000] (08:02:40) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 163.486000]
[ 164.272000] (08:02:40) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 164.272000]
[ 165.526000] (08:02:42) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 165.526000]
[ 165.992000] (08:02:42) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 165.992000]
[ 166.852000] (08:02:43) Rebooting AP due to default-ip is denied in this network (40:e3:d6:ce:f5:48 172.20.166.100)
[ 166.852000]
[ 173.548000]
[ 174.146000] i am master now
[ 174.148000] (08:02:52) !!! Init ---> Master
[ 174.150000] asap_send_elected_master: sent successfully
[ 174.268000] (08:02:52) OOPS. someone else thinks he is the master too, beacon version 4 from 40:e3:d6:ce:f5:48 172.20.166.100 bond0
[ 174.270000] (08:02:53) I am MASTER. recv-ed a master normal-beacon.
[ 174.272000] (08:02:53) master provision, 0 vs. 0
[ 174.274000] (08:02:53) !!! Election result, -5
[ 174.950000] (08:02:53) OOPS. someone else thinks he is the master too, beacon version 4 from 40:e3:d6:ce:f5:48 172.20.166.100 bond0
[ 174.952000] (08:02:54) I am MASTER. recv-ed a master normal-beacon.
[ 174.954000] (08:02:54) master provision, 0 vs. 0
The sys[ 178.684000] asap_mob_pkt_rcv: 13 callbacks suppressed
[ 178.686000] (08:02:57) OOPS. someone else thinks he is the master too, beacon version 4 from 40:e3:d6:ce:f5:48 172.20.166.100 bond0
[ 178.688000] (08:02:58) I am MASTER. recv-ed a master normal-beacon.
[ 178.690000] (08:02:58) master provision, 0 vs. 0
[ 178.694000] (08:02:58) !!! Election result, -5
Sending SIGKILL to all processes.
[ 179.310000] (08:02:58) OOPS. someone else thinks he is the master too, beacon version 4 from 40:e3:d6:ce:f5:48 172.20.166.100 bond0
[ 179.312000] (08:02:59) I am MASTER. recv-ed a master normal-beacon.
[ 179.314000] (08:02:59) master provision, 0 vs. 0
[ 179.316000] (08:02:59) !!! Election result, -5
[ 179.582000] Timed out trying to marshall reboot through user process, rebooting system directly
[ 180.096000] Restarting system.
Anyone any ideas why it is doing this?
