One SSID and multiple VLANs
  • 1.  One SSID and multiple VLANs
    Posted Sep 10, 2014 10:46 AM
    Is it possible to have one SSID and direct the user to different VLANs based on the return of Radius authentication?
    I'm using the bridge mode configuration.
  • 2.  RE: One SSID and multiple VLANs
    Posted Sep 10, 2014 11:19 AM
    Yes you can , what radius server are you using ?
  • 3.  RE: One SSID and multiple VLANs
    Posted Sep 10, 2014 11:22 AM
    We use Microsoft NPS server and 802.1x authentication (EAP-TLS).
  • 4.  RE: One SSID and multiple VLANs
    Posted Sep 10, 2014 11:47 AM
    And in the NPS policy you can speficy the filter-id you want to send back
    Attachment(s)
  • 5.  RE: One SSID and multiple VLANs
    Posted Sep 10, 2014 11:50 AM
    Thank you Victor.
    We will try this.
  • 6.  RE: One SSID and multiple VLANs
    Posted Sep 10, 2014 12:10 PM
    One more question.
    If I create the server rules to set the correct vlan, do I need to set the vlan at the Virtual AP configuration?
  • 7.  RE: One SSID and multiple VLANs
    Posted Sep 10, 2014 12:15 PM
    Unless you want to authenticated user that's not included in the server rules to get a default (VLAN) then you don't.
  • 8.  RE: One SSID and multiple VLANs
    Posted Feb 20, 2015 12:49 PM
    If I set at NPS a rule with an attribute as this:
    Attribute number: 26
    Vendor Code: 14823
    Vendor assigned attribute number: 2
    Atribute format: Decimal
    Atribute value: 64
    Do I need to create a server rule with the same attributes at the server group profile on controller?like this: set vlan condition Class equals "64" set-value 64
