One SSID for multiple authentication types
  • 1.  One SSID for multiple authentication types
    Posted Nov 06, 2015 12:59 AM
    Afternoon,
    I am curious if the following is possible... I want to reduce my network from having 3 SSID (Open, Radius, Certificate) to just 1. Below is my current setup.
    SSID: Onboarding (Open)
    Purpose: Users can connect to Onboarding and they are re-directed to our Onboarding solution which provides them with a certificate based connection.
    SSID: Domain (Domain based Auth with Clearpass/Windows Radius)
    Purpose: Company own machines are connected to the wireless via domain based authenication.
    SSID: Student (Certificated based Auth, CloudPath)
    Purpose: Devices which have done through the onboarding procedure.
    I would love to reduce these down to just 1 SSID which does eerything... does anyone know if that is possible?
  • 2.  RE: One SSID for multiple authentication types
    Posted Nov 06, 2015 04:10 AM
    You can probably reduce it to two.  An SSID can be shared by devices that have the same encryption.  You can have and (1) Open SSID and a (2) WPA2-AES SSID with PEAP and EAP-TLS.  For the 2nd SSID, you can configure ClearPass to use multiple authentication types and then sort it out with rules:
    That is in general.  The specifics of what you are trying to do will require some logic in terms of Roles in ClearPass and Enforcement Policies/Profiles.
  • 3.  RE: One SSID for multiple authentication types
    Posted May 17, 2018 11:35 AM
    I have a similar situation, wanting to reduce the number of SSIDs on campus.  Currently, we have a wpa2-aes SSID.  Could I add wpa2-psk-aes encryption to that SSID for student registered devices (xbox, playstation, tv, etc...), then sort out authentication with Clearpass rules/services as mentioned above?  I'm exploring this right now, but if it is too complicated to sort out the authentication I'll simply bring up another SSID.
    Jeremy
  • 4.  RE: One SSID for multiple authentication types
    Posted May 17, 2018 12:00 PM
    No.
    You can only configure one encryption type per SSID.
    Back in the day you could mix ciphers like this:
    wpa2-psk-tkip
    wpa2-psk-aes
    But you cannot mix encryption types like this:
    wpa2-aes
    wpa2-psk-aes
  • 5.  RE: One SSID for multiple authentication types
    Posted May 17, 2018 12:15 PM
    Bah :)
    Thank you
