Hi there,
I have setup OnGuard Agent for a customer. I noticed that on the Windows 10 Agent settings tab, there is a "Save Credentials" checkbox.
I have disabled authentication (HealthCheck Only). I do happen to have "Use active username in Health mode only" checked.
Is there any way to disable the "Save Credentials" from being displayed? I know it's not going to affect anything if the user clicks it however, I will get less questions if it's removed.
CB
