last person joined: 4 hours ago
OnGuard Agent uninstall
  • 1.  OnGuard Agent uninstall
    Posted Jul 18, 2016 12:50 PM
    Hi:
    Can someone help with an uninstall of the OnGuard Agent from a Windows 7 machine?
    I've looked at: http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Multiple-ways-of-Uninstalling-OnGuard-from-Windows-Client/ta-p/216449
    but that didn't work.
    When I try to re-run the install program, I select English' and then it disappears, and nothing else happens.
    There is no uninst.exe program in the ClearpassOnGuard directory.
    I've even tried doing a Windows system restore, but it fails.
    Is there a tool for uninstalling OnGuard?
    Do I need to purge every registry key that references this program? If so, is there a list of steps for a manual uninstall?
    Thanks.
