I know there are some challenges with RDP into a system, at least with 802.1X authentication, but as it's a multi-user system, it may apply to OnGuard as well. Imagine what would happen if user A is logged in to the console, user B and C through RDP? Which identity should be used then?
If it's just about posture, you may use a health-check without authentication (Health Check Only).
Original Message:
Sent: Jul 25, 2024 03:28 AM
Subject: OnGuard Agent with WinServer 2012 R2 open RDP
With ClearPass OnGuard Agent running on WinServer 2012 R2, i have issue when user login via rdp. Agent usually have status UNKNOWN that OnGuard is not working. Show on log at Agent attems i see "ERROR ancheck 389 Query User Token failed reason = 1314"
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/97bfd88a9722478e8d02e806ec342c11.png)
So when i tryed to switch on user with admin permission of WinServer i have same Error message above. So what must i do to run OnGuard stablebility with Windows Server ?
