Onguard Client "unknown status" issue
  • 1.  Onguard Client "unknown status" issue
    Posted May 30, 2017 06:59 AM
    Hi guys,
    right know I'm sitting at a customer and we implemented Onguard. Everything is working fine but we are facing a problem with the Windows agent.
    After the client is collecting the system information it states for a short time the right client information (e.g. "HEALTHY" or "UNHEALTHY") with the right colour code. After a short time the agent show only the message "UNKNOWN STATUS".
    The Mac agent works fine.
    The only workaround I found is to restart the clearpass agent service. After this the client states the right status until the it's changed again.
    Does anyone have the same problem?
  • 2.  RE: Onguard Client "unknown status" issue
    Posted Jun 01, 2017 09:04 PM
    Please open a TAC case.
  • 3.  RE: Onguard Client "unknown status" issue
    Posted Jun 19, 2018 02:46 AM
    Is the user's PC installed with OnGuard Agent a network environment that allows external network or DNS query?
    It may be a different problem, but if you try to connect a CRL server on the internet when OnGuard Agent is running and there is no internet connection, there may be a delay in checking.
    Thank you.
