Ah, I didn't know that setting the interval removes the retry button. Maybe it's good to open a TAC case to find the optimal solution in your case, if no other responses are posted here.
Original Message:
Sent: Jul 10, 2023 03:44 AM
Subject: OnGuard healthy check reassessment period
Thank you, Herman Robers.
I tried this solution: when we use the health check interval, we cannot put a retry button on the agent (when we put a retry button on the client, the clearpass server will ignore staus from the client for 1 hour). We need a healthy check interval client and a retry button too because some times the agent does not auto-check.
Original Message:
Sent: Jul 06, 2023 07:49 AM
When OnGuard is running, it does contineous testing. If one test fails, it will reach out to ClearPass actively. It depends a bit on the type of test, but in my experience the agent detects changes within minutes or even seconds.
If you need a report regardless status change, you may try setting the Health Check Interval in your Agent enforcement (or in the Onguard global settings).
Original Message:
Sent: Jul 06, 2023 06:47 AM
Can we config OnGuard healthy check reassessment period or not?
We need Onguard agent health checks every 1 hour without disconnecting and connecting to the network. When we test ongaurd agent only healthy check when first network connect.
