Onguard Tokens
  • 1.  Onguard Tokens
    Posted Nov 16, 2017 01:33 AM
    Right now we configured 2 tokens for the posture policy, Healthy and Quarentine. Healthy moves the machine to the corporate network (10.23.0.0) , Quarentine moves it to a limited network (10.30.0.0).  In addition to those 2, I also want to use the Infected token to move the infected machine to blocked network (No network at all).
    Is it possible to use more than 2 tokens at the same posture policy or should i create a dedicated policy only for the infected token.
    Help needed.
    Thank you.
    Shmulik Mazor
  • 2.  RE: Onguard Tokens
    Posted Nov 16, 2017 04:51 AM
    You would need to add a new posture policy then add the new policy to your health check service and the appropriate enforcement. Clients can only have one posture I believe.
  • 3.  RE: Onguard Tokens
    Posted Nov 16, 2017 06:29 AM
    We already did that. We created a new posture policy with the healthy and infected tokens and put it in the web auth service with the healthy and quarentine posture policy and it's not working.
  • 4.  RE: Onguard Tokens
    Posted Nov 16, 2017 09:03 AM
    Posture tokens are assigned as a result of posture policy evaluation. Did you map it in the rules of the posture policy?
