OnGuard - "Use cached roles" Grayed out
  • 1.  OnGuard - "Use cached roles" Grayed out
    Posted Mar 04, 2018 07:12 PM
    Edit: forgot to mention i am running latest 6.7
    pretty new to OnGuard, i am trying to configure it. As far as i understand the authentication flow would look like something like this:
    - client connects and authenticates using dot1x. Because posture is "unknown" the client is placed in a "staging" vlan.
    - At this point the client has an ip and can connect to ClearPass
    - Onguard agent detects it's on the network and send posture information to ClearPass. At this point ClearPass knows whether the client is Healthy or whether it should be quarantined.
    - ClearPass Onguard action is to bounce the port so that the client is forced to reauthenticate, this time with the cached information from the posture.
    Problem is within the Webauth service that has the posture enabled, i cannot enable "Use cached roles and posture attributes", it is greyed out, therefore the client posture is always unknown.
    Any ideas?
    thanks
  • 2.  RE: OnGuard - "Use cached roles" Grayed out
    Posted Mar 04, 2018 08:50 PM
    Under the cluster wide parameters try changing the default (default value is 5 minutes) policy cache timeout .
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: OnGuard - "Use cached roles" Grayed out
    Posted Mar 04, 2018 08:53 PM
    thanks!.
    so no matter whether the service has that enabled, it will cache the client for 5 minutes by default?
  • 4.  RE: OnGuard - "Use cached roles" Grayed out
    Posted Mar 04, 2018 09:02 PM
    By default it is set to 5 minutes but you can increase it but should also
    consider having the agent to send a keep-alive periodically (Under Global
    Onguard Settings) and if the posture is healthy from a known device then
    dont bounce the port and if it is unhealthy then bounce the port.
  • 5.  RE: OnGuard - "Use cached roles" Grayed out
    Posted Mar 05, 2018 10:24 PM
    Thanks. For some reasons documents i have found all point to tick that box in the webauth, although maybe in 6.7 that is not the case, it works anyway.
