Only 8 out of 10 IAP 315 are joined to virtual controller
  • 1.  Only 8 out of 10 IAP 315 are joined to virtual controller
    Posted Jun 04, 2018 12:58 AM
    I have 10 IAP 315. When I start to setup I found only 8 can join to virtual controller. Another 2 is joined to the separted virtual controller. I try assigned same virtual controller IP  but it's not still joining.
    I connected all 10 APs to one PoE switch with no uplink. Please advice how can I solve this issue.Thanks
  • 2.  RE: Only 8 out of 10 IAP 315 are joined to virtual controller
    Posted Jun 04, 2018 02:46 AM
    There are several questions to answer here. I would start with these ones:
    - Are they all Instant APs?
    - Are they running the same firmware version?
    - Are they configured in the same VLAN?
    HTH
    Kevin
  • 3.  RE: Only 8 out of 10 IAP 315 are joined to virtual controller
    Posted Jun 04, 2018 02:51 AM
    Hi Bro Kevin,
    Yes, All IAPs
    Same Firmware
    Same VLAN
    all are just in factory default setting.
    @kevin_pm
  • 4.  RE: Only 8 out of 10 IAP 315 are joined to virtual controller
    Posted Jun 04, 2018 03:01 AM
    Alright, thanks for the quick response. Let´s have a look at the following logs:
    - show log debug
    - show log ap-debug
    - show log system
    - show swarm mode
    - show swarm state
    Some questions:
    - how are the APs getting the IP addresses?
    - do you know the IP addresses/ MAC addresses of those APs that are not joining the cluster (good for debugging purposes)?
    Kevin
  • 5.  RE: Only 8 out of 10 IAP 315 are joined to virtual controller
    Posted Jun 04, 2018 03:13 AM
    Hi Bro,
    Currently, I am not with all 10 APs.But I take 3 APs (2 are those that cant join and 1 is from 8 joinable clusters)
    to test at my home. For now testing all these 3 APs are in the same Virtual controller. Is there any maximum number of AP for the virtual controller? I can show u log tomorrow. Thank you.
  • 6.  RE: Only 8 out of 10 IAP 315 are joined to virtual controller
    Posted Jun 04, 2018 03:34 AM
    The maximum tested IAP cluster size is 128 IAPs in a cluster. So I guess that it should not be a problem. However, it would be interesting to check the logs if the problem remains
    Kevin
  • 7.  RE: Only 8 out of 10 IAP 315 are joined to virtual controller
    Posted Jun 12, 2018 06:55 AM
    Hi Bro,
    When I add all AP to cloud central it all work.
    Thanks for your reply and support.
  • 8.  RE: Only 8 out of 10 IAP 315 are joined to virtual controller
    Posted Jun 12, 2018 11:03 AM
    Great, glad to read that!
    All the best,
    Kevin
