Open Wi-Fi Traffic
  • 1.  Open Wi-Fi Traffic
    Posted Aug 13, 2012 03:37 PM
    I have a quick question about the Open (Guest) SSID traffic. Is there any way we can encrypt the Guest user traffic AFTER the user has authenticated and assigned a role?
    Also, there is a GRE Tunnel between the client and the controller, though there's no encryption, correct? So, for a packet capture, its still difficult to sniff the actual packets AFTER the user is authenticated? Please let me know.
    Thanks.
  • 2.  RE: Open Wi-Fi Traffic
    Posted Aug 14, 2012 09:37 PM
    For the first questions I don't think it is possible.
    For 2nd question, traffic from AP to controller is GRE encapsulated. If you want to sniff those packets, Aruba has a wireshark version with plug-in enable to look inside the GRE encapsulation.
    You can get it from Aruba support site --> Tools and Resourcer --> Wireshark
  • 3.  RE: Open Wi-Fi Traffic
    Posted Aug 20, 2012 02:03 PM
    Thanks for the info, Aalap!
