Operator filters for Guest MAC registered device management
  • 1.  Operator filters for Guest MAC registered device management
    Posted May 26, 2022 04:56 PM
    We use ClearPass Guest for device MAC registration. Our students and staff can manage their own devices, but have the filter in their operator profile set to be "Only show accounts created by the operator". This is what we want. But recently we switched from ADFS to AzureAD for Guest auth and it looks like now when someone registers a device the device shows as registered by (I think this is the 'sponsor_name' field) userid@domain rather than just userid. And when users go to view their devices it seems like they only see the devices that were registered recently (we have had people saying that their devices have 'disappeared', but admins can see them in the devices db). So we're guessing that since the Azure switch the authenticated user (or operator) is also being picked up as userid@domain, rather than just userid, and so the filter that is applied to their view of devices is only showing those devices that they created since the move to Azure.
    Or at least we think that is what is happening.
    If we're right then I guess one solution would be to script something to use the API to add @domain to the end of the sponsor_names for all the existing devices that were registered by just 'userid'. That's doable but seems a bit inelegant
    But I was wondering if there is something smarter we can do in the operator filters, maybe use a regex so that the filter shows devices with sponsor_name of 'userid' and by 'userid@domain'
    I see there is a User Account Filter in the operator profile but I don't know if that can help, or how I would go about writing something for this use-case.
    Any help much appreciated.
    Guy
    Guy Goodrick
  • 2.  RE: Operator filters for Guest MAC registered device management
    Posted 26 days ago
    As you mention, userid and userid@domain are different users so will not show up when showing just your own accounts.
    The User Account Filter will probably not help either, as if I check the documentation it only checks attributes to values, not the username against a derived variable. Your suggestion about going in change all sponsor_names may be a good solution.
  • 3.  RE: Operator filters for Guest MAC registered device management
    Posted 25 days ago
    Thanks Herman, we will go ahead with that then
