Optimal RF configuration IAP-335
  • 1.  Optimal RF configuration IAP-335
    Posted Mar 13, 2018 07:26 AM
    Hi everyone. Hope all is well with you. I was wondering what would be the optimal RF configuration for two IAP-335 deployed in a 4,300 sqft brick apartment. They are connected to a Humax modem through a TP-Link 8p POE+ switch. The modem is connected to the ISP providing 250mb down / 20mb up. Below, it's the current config. Thank you in advance.
    Airtime Fairness Mode: preferred Access
    ClientMatch Calculating Interval: 3 seconds
    ClientMatch Neighbor Matching: 60 %
    ClientMatch Threshold: 5
    Spectrum Load Balancing Mode: Channel + Radio
    Min Transmit Power: 18
    Max Transmit Power: Max
    Client Aware: On
    Scanning: On
    Legacy Only: Off
    802.11d / 802.11h: On
    Beacon Interval: 100 ms
    Interference Immunity Level: 2
    Channel Switch Announcement Count: 0
    Background Spectrum Monitoring: Off
    Customize ARM Power Range: Off
    Very High Throughput: On
  • 2.  RE: Optimal RF configuration IAP-335
    Posted Mar 20, 2018 10:55 PM
    Hard to give advice without understanding a bit more about the RF environment.
    Are there any issues or concerns with the wireless access?
    Take a look at the following for some recommendations/best practices.
    http://community.arubanetworks.com/t5/Validated-Reference-Design/Aruba-802-11ac-Networks/ta-p/242637
    It's for Controller based networks but still applicable to the IAP.
