The main thing is to make sure that the RSSI seen between the two is as high as possible. Double check the transmit powers configured, make sure that you are operating in a channel that allows for the higher transmit powers, check the RSSI for the link. Make sure no WLANs are configured to operate on the 5 GHz radios. Reduce broadcast and multicast traversing the mesh link as much as possible to reduce wasted airtime.
Carson Hulcher, ACEX#110
Original Message:
Sent: May 23, 2024 02:22 PM
Subject: Optimizing Mesh connection
Recently configured a mesh connection to get network access to an outdoor classrom we built. Everything is working great, just curious if there was anything to look at to make sure it's optimized? This is the first mesh I've setup, so I'm not sure what to check. I followed the "Simple Mesh Deployment Guide". Below are iperf results from my laptop plugged into the switch at the classroom side.
[ ID][Role] Interval Transfer Bitrate
[ 5][TX-C] 0.00-60.00 sec 2.30 GBytes 329 Mbits/sec sender
[ 5][TX-C] 0.00-60.01 sec 2.30 GBytes 329 Mbits/sec receiver
[ 7][RX-C] 0.00-60.00 sec 1.51 GBytes 216 Mbits/sec sender
[ 7][RX-C] 0.00-60.01 sec 1.51 GBytes 216 Mbits/sec receiver
iperf Done.
