Option 82 Sub Option 1 Field is Blank?
  • 1.  Option 82 Sub Option 1 Field is Blank?
    Posted Dec 05, 2014 09:54 AM
    Dear All,
    We have a 7240 controller and upon activationg the option 82 feature we are only getting sub option 2 (eSSID) with wireshark. And the sub option 1 field (MAC of the AP) is filled with all zeros. Anyone came acros with this?
    Thank you.
    #7240
  • 2.  RE: Option 82 Sub Option 1 Field is Blank?
    Posted Dec 05, 2014 10:03 AM
    Which AOS version you are using ?
    Cheers,
    Venu Puduchery
  • 3.  RE: Option 82 Sub Option 1 Field is Blank?
    Posted Dec 05, 2014 10:05 AM
    We have 6.4.2.2.
  • 4.  RE: Option 82 Sub Option 1 Field is Blank?
    Posted Dec 15, 2014 02:50 AM
    Any ideas?
  • 5.  RE: Option 82 Sub Option 1 Field is Blank?
    Posted Dec 15, 2014 10:14 AM
    omergencay
    Are you doing something like split tunnel or bridge?
    turn on some debug and see what it says. For a sample config such as
    interface vlan 1
      ip helper-address 192.168.1.245
      option-82 mac essid
    below is some sample debug that shows the BSSID being added, you can enable the same debugs and see if you can see your BSSID being added.
    logging level debugging user
    logging level info system
    logging level debugging network process dhcpd subcat dhcp
    logging level debugging network process dhcpd subcat packet-dump
    logging level debugging system process dhcpd
    Oct 9 18:01:24 :399814:  <DBUG> |dhcpdwrap|  DHCPD: Added client MAC 00:21:6B:0B:2A:A0 BSSID = 00:24:6C:22:47:89
    Oct 9 18:01:27 :202541:  <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x40 opcode 0x5a ingress 0x10cb vlan 20 egress 0x14 src mac 00:21:6b:0b:2a:a0
    Oct 9 18:01:27 :202534:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan20: DISCOVER 00:21:6b:0b:2a:a0 Options 74:01 3d:0100216b0b2aa0 0c:7063 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Oct 9 18:01:27 :202523:  <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=300, from_port=68, op=1, giaddr=0.0.0.0
    Oct 9 18:01:27 :399814:  <DBUG> |dhcpdwrap|  DHCPD: Adding option 82 for client MAC 00:21:6B:0B:2A:A0 with BSSID = 00:24:6C:22:47:89
    Oct 9 18:01:27 :202532:  <DBUG> |dhcpdwrap| |dhcp| got 1 relay servers
    Oct 9 18:01:27 :202533:  <DBUG> |dhcpdwrap| |dhcp| Relayed: DISCOVER server=192.168.1.245 giaddr=172.16.1.156 MAC=00:21:6b:0b:2a:a0
    Oct 9 18:01:27 :202523:  <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=309, from_port=67, op=1, giaddr=172.16.1.156
    Oct 9 18:01:27 :202541:  <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x0 vlan 1 egress 0x1028 src mac 00:0b:86:62:0b:60
    regards
    -jeff
