Wired Intelligent Edge
Options for connecting 8320 and 2930M switches
  • 1.  Options for connecting 8320 and 2930M switches
    Posted Feb 11, 2021 12:58 PM
    I'd like some help understanding the options for connecting 2 types of switches. I would like to connect them at the highest speed possible.
    I have 2 JL581A 8320 switches which I want to connect to 2 JL322A 2930M switches in a stack.
    Each 2930M can accommodate a module for a 40G QSFP+ transceiver but these modules are already being used for other connections on the network.
    So I am left with the front-facing ports on the 2930M, but I need some help checking I have the correct SFP transceiver cable to connect to the 8320 switches.
    It looks like this transceiver is the best option: Aruba 10G SFP+ to SFP+ 3m DAC Cable (J9283D)
    If you are able to confirm, or suggest better options that would be great.
    Thanks for you help.
    Adam Bishop
  • 2.  RE: Options for connecting 8320 and 2930M switches
    MVP GURU
    Posted Feb 11, 2021 01:48 PM
    The front SFP ports will only handle 1Gb, not 10Gb. You have options to replace the rear unit with JL083A which will give you 4 x 10Gb Ethernet - SFP+.
    The Aruba 10G SFP+ to SFP+ 3m DAC Cable (J9283D) is a 10Gb DAC cable.
    Dustin Burns
