OS 6.4 and AP-61
  • 1.  OS 6.4 and AP-61
    Posted Jan 19, 2015 09:15 AM
    Dear All;
    I have an Aruba Controller 3600 with OS 6.3.1.2 and a lot of AP-61,AP-68 and IAP-93.
    Now I purchased a new 15 IAP-103, but cannot join the controller.
    I have to upgrade the controller to OS 6.4 but as I read at release notes it not supporeted AP-61.
    What can I do ??
    #3600
  • 2.  RE: OS 6.4 and AP-61
    Posted Jan 19, 2015 09:17 AM
    You can either use your new IAP-103 in Instant mode or replace your AP-61s.
  • 3.  RE: OS 6.4 and AP-61
    Posted Jan 19, 2015 09:18 AM
    You have to make a choice, unfortunately.
    http://www.arubanetworks.com/support-services/end-of-life-products/
  • 4.  RE: OS 6.4 and AP-61
    Posted Jan 19, 2015 03:37 PM
    Thank you for All Replies ;
    So OS 6.4 doesn't support AP-61,  Although the end of support date for AP-61 is 31-May-16. it's make a confusion.
  • 5.  RE: OS 6.4 and AP-61
    Posted Jan 19, 2015 04:16 PM
    end-of-support means TAC will no longer support the AP but because Aruba will offer different version of AOS, the AP-61 will remain supported on AOs 6.3 until the end of support date for the AP.
