OS 8 VMC ova deployment - disk size
  • 1.  OS 8 VMC ova deployment - disk size
    Posted Nov 30, 2017 02:46 PM
    I'm trying to deploy a vmc 250 from ova file.
    According to installation notes minimum requirement for flash/ disk is 8 GB.
    But during ova deployment there is no option to set the disk size (two vdisks are deployd, 4 and 6 GB accordingly).
    After initial setup, the command "show storage" shows a mount point /flash 6 GB.
    If I manually expand the virtual disk, the file system must also be expanded (how?).
    Any help appreciated
    John
