Wired Intelligent Edge
OSPF flapping need to look at logs
  • 1.  OSPF flapping need to look at logs
    Posted Aug 20, 2019 12:36 PM
    Folks,
                  I am new to aruba swicthes. I have configured a couple of aruba switches in area 0 ospf and i am seeing routes being removed and then added back in the routing table. I want to collect some logs in the switches or run debug on these switches. Can someone please tell me how to accomplishing logging and debugging on aruba switches please.
    Here is the output from show version of the switch.also please can any one check if i have configured ospf correctly on a vsx enabled switch.
    (c) Copyright 2017-2019 Hewlett Packard Enterprise Development LP
    Version : TL.10.02.0050
    Build Date : 2019-06-05 08:02:01 PDT
    Build ID : ArubaOS-CX:TL.10.02.0050:949fdb775550:201906051447
    Build SHA : 949fdb775550cec83d71f4c3595121a5c1253864
    Active Image : primary
    Service OS Version : TL.01.03.0008
    BIOS Version : TL-01-0013
    vsx
    GLF-011007EOR-01# show version
    ArubaOS-CX
    GLF-011007EOR-01# show run
    Current configuration:
    !Version ArubaOS-CX TL.10.02.0050
    hostname nnnn
    u
    vrf KEEPALIVE-EOR-A
    ntp enable
    ssh server vrf default
    ssh server vrf mgmt
    router ospf 50
    router-id 10.16.14.15
    redistribute connected
    area 0.0.0.0
    vlan 1
    vlan 1664
    name TXRSVT_FedPortGroup
    vsx-sync
    ip igmp snooping enable
    vlan 1666
    name TXRSVT_StoragePortGroup
    vsx-sync
    vlan 1668
    name TXRSVT_StorePG
    vsx-sync
    vlan 1670
    name TXRSVT_ManagementPG
    vsx-sync
    vlan 1680
    name TORMGMT1680
    vsx-sync
    vlan 1682
    name TXRSTORV1
    vsx-sync
    vlan 1690
    name TXRMGMTINT
    vsx-sync
    vlan 1692
    name TXRINFINT
    vsx-sync
    vlan 1694
    name TXRAPPINT
    vsx-sync
    vlan 2668
    name TXRESX
    vsx-sync
    vlan 2680
    name TXRSERVEREGG
    vsx-sync
    spanning-tree config-name d0:67:26:a6:95:60
    interface mgmt
    no shutdown
    ip dhcp
    interface lag 100 multi-chassis
    no shutdown
    no routing
    vlan access 2680
    lacp mode active
    lacp rate fast
    qos trust dscp
    spanning-tree root-guard
    interface lag 112 multi-chassis
    no shutdown
    no routing
    vlan trunk native 1680
    vlan trunk allowed all
    lacp mode active
    lacp rate fast
    qos trust dscp
    interface lag 113 multi-chassis
    no shutdown
    no routing
    lacp mode active
    lacp rate fast
    qos trust dscp
    interface lag 114 multi-chassis
    no shutdown
    no routing
    lacp mode active
    lacp rate fast
    qos trust dscp
    interface lag 115 multi-chassis
    no shutdown
    no routing
    lacp mode active
    lacp rate fast
    qos trust dscp
    interface lag 116 multi-chassis
    no shutdown
    no routing
    lacp mode active
    lacp rate fast
    qos trust dscp
    interface lag 117 multi-chassis
    no shutdown
    no routing
    lacp mode active
    lacp rate fast
    qos trust dscp
    interface lag 118 multi-chassis
    no shutdown
    no routing
    lacp mode active
    lacp rate fast
    qos trust dscp
    interface lag 200 multi-chassis
    no shutdown
    no routing
    vlan trunk native 1
    lacp mode active
    lacp rate fast
    qos trust dscp
    interface 1/1/1
    description GLF-FWCORP-01A ETH1/23
    no shutdown
    mtu 9198
    lag 100
    interface 1/1/2
    description GLF-011007TOR1-01 1/1/51
    no shutdown
    lag 112
    interface 1/1/3
    description GLF-011007TOR2-01 1/1/51
    no shutdown
    lag 113
    interface 1/1/4
    description GLF-011007TOR3-01 1/1/51
    no shutdown
    lag 114
    interface 1/1/5
    description GLF-011007TOR4-01 1/1/51
    no shutdown
    lag 115
    interface 1/1/6
    description GLF-011007TOR5-01 1/1/51
    no shutdown
    lag 116
    interface 1/1/7
    description GLF-011007TOR6-01 1/1/51
    no shutdown
    lag 117
    interface 1/1/8
    description GLF-011007TOR7-01 1/1/51
    no shutdown
    lag 118
    interface 1/1/30
    no shutdown
    vrf attach KEEPALIVE-EOR-A
    ip address 10.16.0.109/30
    interface 1/1/31
    vsx-sync access-lists qos vlans
    no shutdown
    mtu 9198
    qos trust dscp
    no routing
    vlan trunk native 1 tag
    interface 1/1/32
    no shutdown
    lag 200
    interface loopback 0
    ip address 10.16.14.15/32
    ip ospf 50 area 0.0.0.0
    interface vlan1664
    vsx-sync active-gateways policies
    description Simplivity Federation
    ip address 10.16.64.2/23
    active-gateway ip 10.16.64.1 mac 00:00:00:00:16:80
    ip pim-sparse enable
    interface vlan1666
    description Simplivity Storage
    ip address 10.16.66.2/23
    active-gateway ip 10.16.66.1 mac 00:00:00:00:16:80
    interface vlan1668
    description Simplivity Virtual 1
    ip address 10.16.68.2/23
    active-gateway ip 10.16.68.1 mac 00:00:00:00:16:80
    interface vlan1670
    description Simplivity Virtual 2
    ip address 10.16.70.2/23
    active-gateway ip 10.16.70.1 mac 00:00:00:00:16:80
    interface vlan1680
    ip address 10.16.80.2/23
    active-gateway ip 10.16.80.1 mac 00:00:00:00:16:80
    interface vlan1682
    description Storage for Nimble production
    ip address 10.16.82.2/23
    active-gateway ip 10.16.82.1 mac 00:00:00:00:16:80
    interface vlan1690
    description OOB Management and ILO
    ip address 10.16.90.2/23
    active-gateway ip 10.16.90.1 mac 00:00:00:00:16:80
    interface vlan1692
    description Infrastructure Internal VMs for Domain Controllers and DNS
    ip address 10.16.92.2/23
    active-gateway ip 10.16.92.1 mac 00:00:00:00:16:80
    interface vlan1694
    description Applications Internal
    ip address 10.16.94.2/23
    active-gateway ip 10.16.94.1 mac 00:00:00:00:16:80
    interface vlan2668
    description ESXHost
    ip address 10.16.168.2/23
    active-gateway ip 10.16.168.1 mac 00:00:00:00:16:80
    interface vlan2680
    ip address 10.16.180.2/23
    active-gateway ip 10.16.180.1 mac 00:00:00:00:16:80
    vsx
    inter-switch-link 1/1/31
    role primary
    keepalive peer 10.16.0.110 source 10.16.0.109 vrf KEEPALIVE-EOR-A
    vsx-sync aaa copp-policy dns mclag-interfaces qos-global sflow snmp ssh static-routes time
    router pim
    enable
  • 2.  RE: OSPF flapping need to look at logs
    Posted Aug 21, 2019 01:03 PM
    Greetings!
    To start, you can check the event logs in AOS-CX using the command show events (you can add the -r flag to show them in reverse chronological order, with newest entries on top).
    For additional logging, you can enable OSPFv2 debugging and view debug logs using the following commands:
    switch# debug destination buffer
    switch# debug ospfv2
    switch# show debug buffer
    You can also specify the current console session as the debug destination by replacing buffer with console.
    To disable debug logging:
    switch# no debug ospfv2
    switch# no debug destination buffer
