OTP with Aruba 105 IAP
  • 1.  OTP with Aruba 105 IAP
    Posted Dec 02, 2014 02:23 AM
    I have one Aruba 105 IAP. I want to create one Guest SSID with Using OTP for credential .
    Is it possible to enable OTP with Guest SSID?
    If any additional things[like otp server] required please mention.
    Thanks in advanced.
  • 2.  RE: OTP with Aruba 105 IAP
    Posted Dec 02, 2014 06:03 AM
    What radius server do you have?
  • 3.  RE: OTP with Aruba 105 IAP
    Posted Dec 02, 2014 06:10 AM
    AD 2008R2
  • 4.  RE: OTP with Aruba 105 IAP
    Posted Dec 02, 2014 06:18 AM
    You'd want a captive portal with your RADIUS server as the authentication source.
  • 5.  RE: OTP with Aruba 105 IAP
    Posted Dec 02, 2014 07:51 AM
    NO! i want to use OTP for Guest access.
  • 6.  RE: OTP with Aruba 105 IAP
    Posted Dec 02, 2014 07:55 AM
    What OTP service are you using?
    You need to give more detail.
  • 7.  RE: OTP with Aruba 105 IAP
    Posted Dec 02, 2014 08:00 AM
    Now i am not using any otp service, but if it is possible then only i'll use otp service.
  • 8.  RE: OTP with Aruba 105 IAP
    Posted Dec 22, 2014 11:18 AM
    in general it should be possible. just feed the one time password and username from the captive portal via radius to OTP server, most of them support RADIUS (RSA, SafeNet, ..).
    still there are some caveats which such an approach, espcially with a timeout and when your browser reuses old credentials.
