OUI classification not working?
  • 1.  OUI classification not working?
    Posted Jun 24, 2015 11:13 PM
    I have a large number of rogues hitting the default classification in RAPIDS.
    On inspection the problems seems to be with OUI score..
    My rules are something like this:
    1) Rogues = >-75, OUI score between 2 and 4
    2) Sus. Rogues = >-75, OUI score 1
    3) Otherwise unclassified
    So when I look at a particular example it should have a OUI score of 3:
    $grep 00-0B-6B /usr/local/airwave/lib/perl/Mercury/OUI/updates/oui_data.csv
    "00-0B-6B","Wistron Neweb Corp.","Wistron Neweb Corp.","1","1","1",""
    But it clearly hits rule 3 due to a score of 0, since signal is > -75.
    Otherwise the rules work as I can change them and rogues get reclassified. Am I missing something about the way OUI score works or is this an issue?
    AMP 8.0.8.1
  • 2.  RE: OUI classification not working?
    Posted Jun 25, 2015 12:43 AM
    Following up, it certainly seems to an issue with Airwave.
    Any working rule that has any combination of OUI score added to it produces no matches. Min of 1 should match anything but matches nothing, looking very much like OUI is 0 regardless or a broken score.
  • 3.  RE: OUI classification not working?
    Posted Jun 25, 2015 11:52 AM
    Please open a support case to help track this as a defect.
  • 4.  RE: OUI classification not working?
    Posted Jun 30, 2015 08:33 PM
    Don't really have the 4 hours of unpaid time this typically takes.
    I believe this qualifies as an old feature that has become broken through an update and was probably not included as part of any automated test routines.
