Outdoor Access Point 375 power over ethernet
  • 1.  Outdoor Access Point 375 power over ethernet
    Posted Jun 08, 2018 01:27 AM
    Hi Dears,
    Hope you guys are doing good.
    We are deploying Aruba outdoor Access Points Model number(JZ177A) 375 which has 2 ports(1 Copper & 1 SFP), we are planning to connect access point on optical fiber keeping in mind distance limitation of copper above 100 meters.
    Vertical pole does not have feasibility for power source hence we are using POE+ injector to power on the access point and data over fiber optics.
    Will it work, has anyone done that in past.
    Hardik.
  • 2.  RE: Outdoor Access Point 375 power over ethernet
    Posted Jun 08, 2018 04:06 AM
    It will work fine to power with POE on the ENET and data connect on the fiber, just make sure the wired/POE is not providing DHCP to the AP.
  • 3.  RE: Outdoor Access Point 375 power over ethernet
    Posted Sep 04, 2018 07:35 AM
    To make the first connection to the AP over Optic SFP worked fine.
    Problem was: as soon you add any configuration to the AP (like a SSID) it lost IP connection over sfp - enet1 / moved back to ethernet again and it worked.
    in the CLI I could see that enet1 was set to bridge and had ip adress 169.x.x.x.
    It took a couple of hours to find out why, not even support did now what was wrong. :-/
    You must create a own Wired-port-profile for the SFP and deploy it to the enet1 interface. Like this example: My profil is called "Fiber"
    wired-port-profile Fiber
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    uplink-enable
    trusted
    no shutdown
    access-rule-name Fiber
    speed auto
    duplex auto
    no poe
    type employee
    auth-server InternalServer
    captive-portal disable
    no dot1x
    enet1-port-profile Fiber
    This pages has information how to do:
    https://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/UG_files/Wired_port_profile/ConfiguringEthernetPt_1.htm
    https://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/UG_files/Wired_port_profile/AssigningEthProfiles.htm
    https://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/UG_files/Wired_port_profile/ConfiguringEthernetPt_2.htm
