Outdoor Access Points with Built in Directional Antenna
  • 1.  Outdoor Access Points with Built in Directional Antenna
    Posted Jan 03, 2018 06:24 AM
    I have never used an Outdoor Access Points with Built in Directional Antenna before. I wonder if the Aruba AP-367 will help me in connecting 2 buildings 600m away. I have nothing in between them to block the signal.
  • 2.  RE: Outdoor Access Points with Built in Directional Antenna
    Posted Jan 03, 2018 06:40 AM
    Yes, this is absolutly possible.
    With that setupup you could archive around 400 Mbps. The 367 is good for P2P up to 1 km.
    If you are using APs with external more narrow Antennas you could get better results. As an example 274+5314.
    Depends on what you are expecting.
  • 3.  RE: Outdoor Access Points with Built in Directional Antenna
    Posted Jan 03, 2018 06:46 AM
    Many Thanks. 400 Mbps is enough for me. Will use this solution.
  • 4.  RE: Outdoor Access Points with Built in Directional Antenna
    Posted Jan 09, 2018 06:41 PM
    Just a quick correction from 'cordless's' comment, a 367 PtP at 600m resulting in 400Mbps is ONLY with clean RF at VHT80. if you have noise, or have to use narrower channels, that number will go down.
