Outdoor AP-365 AP-367 not Up with Aruba 7210 Controler
  • 1.  Outdoor AP-365 AP-367 not Up with Aruba 7210 Controler
    Posted Jun 17, 2017 07:28 PM
    Hello Friends,
    I have WLAN deployment where Indoor APs (207) came UP with the Controller 7210 while the Oudoor ones (365, 367) couldn't be controlled. All the cabling is good and tested. Those APs got their IP adresses from DHCP but couldn't be Up on the CTRL (the CTRL is Layer 2 connected to all APs)
    Is there any specific firmware loading that need to be done for those Outdoor APs? It is strange since I didn't get that problem with the Indoor ones.
    Could you please help me with this?
    Thanks in advance
  • 2.  RE: Outdoor AP-365 AP-367 not Up with Aruba 7210 Controler
    Posted Jun 17, 2017 07:50 PM
    6.5.2 for the AP 365.
    Type show log system 50 on the controller command line to see what is happening.
  • 3.  RE: Outdoor AP-365 AP-367 not Up with Aruba 7210 Controler
    Posted Jun 17, 2017 08:39 PM
    Did the AP receive Master Controller IP.
    #AirheadsMobile
  • 4.  RE: Outdoor AP-365 AP-367 not Up with Aruba 7210 Controler
    Posted Jun 17, 2017 09:20 PM
    Actually, the AP is Layer 2 connected with the CTRL, so no need to get the controller-ip.
    For the firmware, my CTRL is running 6.5.1.5 version.
    Colin, are you sure that this AP requires 6.5.2 ?
  • 5.  RE: Outdoor AP-365 AP-367 not Up with Aruba 7210 Controler
    MVP EXPERT
    Posted Jun 18, 2017 05:01 AM
    Hey, yep the ArubaOS code is 6.5.2.0.
    http://www.arubanetworks.com/assets/ds/DS_AP360Series.pdf
    Do you also have the ability to attach a console cable to the AP and verify the behaviour?
  • 6.  RE: Outdoor AP-365 AP-367 not Up with Aruba 7210 Controler
    Posted Jun 18, 2017 08:10 AM
    Yes.
  • 7.  RE: Outdoor AP-365 AP-367 not Up with Aruba 7210 Controler
    Posted Jun 18, 2017 09:48 AM
    Thanks a lot.
    Could you please share with me the link to download this version.
  • 8.  RE: Outdoor AP-365 AP-367 not Up with Aruba 7210 Controler
    Posted Jun 18, 2017 09:49 PM
    support.arubanetworks.com
