last person joined: 4 hours ago
Outdoor AP 365 keeps rebooting - memory failed?
  • 1.  Outdoor AP 365 keeps rebooting - memory failed?
    Posted Sep 20, 2017 07:46 PM
    I receive following message from console, and I tried to reset this AP few times, no change...I am stuck now.
    Any suggestion? Thanks in advanced.
    APBoot 2.1.4.7 (build 57679)
    Built: 2016-12-08 at 15:43:35
    Model: AP-36x
    DRAM:  512 MiB
    Flash: Detected W25Q32FV_SPI: total 4 MiB
    NAND:  128 MiB
    Power: POE
    Net:   eth0
    Radio: ipq4029#0, ipq4029#1
    Reset: warm
    FIPS:  passed
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0x0
    Invalid image format version: 0x0
    Checking image @ 0x2000000
    Copying image from 0x84000000
    Image is signed; verifying checksum... passed
    SHA2 Signature available
    Signer Cert OK
    Policy Cert OK
    RSA signature verified using SHA2.
    Uncompressing Kernel Image ... OK
    [    0.000000]
    [    0.000000] Aruba Networks
    [    0.000000] ArubaOS Version 6.5.2.0-6.5.2.0 (build 57911 / label #57911)
    [    0.000000] Built by p4build@lesbos on 2017-01-03 at 19:47:26 PST (gcc version 4.6.3)
    [    0.000000]
    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
    [    0.023927] SMP: Total of 4 processors activated (384.00 BogoMIPS).
    [    0.052224] i2c-gpio driver registered
    [    9.224568] 3 ofpart partitions found on MTD device 7980000.qcom,nand
    [    9.295051] Creating 3 MTD partitions on "7980000.qcom,nand":
    [    9.363787] 0x000000000000-0x000002000000 : "aos0"
    [    9.463401] 0x000002000000-0x000004000000 : "aos1"
    [    9.550459] 0x000004000000-0x000008000000 : "ubifs"
    [    9.684429] m25p80 spi0.0: found w25q32, expected n25q128a11
    [    9.764890] Found AT97SC3203 on MSM-I2C-v2-adapter
    [    9.815188] Key type dns_resolver registered
    [    9.860839] Registering SWP/SWPB emulation handler
    [   11.555704] TZ dump found for reboot
    [   11.634946]
    Starting Kernel SHA1 KAT ...
    [   11.669432] Completed Kernel SHA1 KAT
    [   11.716259] Starting Kernel HMAC-SHA1 KAT ...
    [   11.766447] Starting Kernel DES KAT ...[   11.812227] Completed Kernel DES KAT
    [   11.855887] Starting Kernel AES KAT ...
    [   11.899664] Completed Kernel AES KAT
    [   11.899664]
    [   11.963252] Starting Kernel AESGCM KAT ...
    [   12.010007] Completed Kernel AESGCM KAT
    [   12.059291] Completed Kernel HMAC-SHA1 KAT
    Thu Jan  1 00:00:00 PST 1970
    [   12.264591] msm_nand_read_oob: 0x5b01800 datalen 0x800 ooblen 0 err -74 corrected 0
    [   12.343822] UBI warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 216:4096, read only 2048 bytes, retry
    [   12.488611] msm_nand_read_oob: 0x5b01800 datalen 0x800 ooblen 0 err -74 corrected 0
    [   12.579245] UBI warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 216:4096, read only 2048 bytes, retry
    [   12.724022] msm_nand_read_oob: 0x5b01800 datalen 0x800 ooblen 0 err -74 corrected 0
    [   12.814657] UBI warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 216:4096, read only 2048 bytes, retry
    [   12.959412] msm_nand_read_oob: 0x5b01800 datalen 0x800 ooblen 0 err -74 corrected 0
    [   13.050095] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 216:4096, read 2048 bytes
    [   13.179907] UBI assert failed in ubi_io_read at 202 (pid 119)
    [   13.248656] UBIFS error (pid 119): ubifs_leb_read: reading 126976 bytes from LEB 5:0 failed, error -5
    [   13.358910] UBIFS error (pid 119): ubifs_start_scan: cannot read 126976 bytes from LEB 5:0, error -5
    mount: Mounting ubi2:ubifs on /aruba/fs failed: Input/output error
    Mount ubifs fail
    Will reboot to mount ubifs
    killall: nanny: no process killed
    killall: sapd: no process killed
    cd: 15: can't cd to /tmp/apfc
    apfcutil: read failed: Is a directory
    killall: wdg: no process killed
    SIOCSIFADDR: No such device
    The system is going down NOW !!
    Sending SIGKILL to all processes.
    Unmounting UBIFS failed.  Please report this error (Invalid argument).
    Please stand by while rebooting the system.
    [   23.113716] reboot: Restarting system
  • 2.  RE: Outdoor AP 365 keeps rebooting - memory failed?
    Posted Sep 20, 2017 08:02 PM
    I'd guess that your assessment that there's a memory or bus failure is probably a good bet.
    Go to TAC (go directly to TAC, do not pass GO etc.) [is a board-game joke lost in modern Internet culture?]
    Open a support case and have that AP looked at.
  • 3.  RE: Outdoor AP 365 keeps rebooting - memory failed?
    Posted Sep 21, 2017 12:44 AM
    Thanks buddy. I just create a case with TAC.
