Outdoor AP via coax POE
  • 1.  Outdoor AP via coax POE
    Posted May 15, 2018 11:48 AM
    Howdy all,
    I am currently considering an outdoor only implementation using a potential mix of AP-360, 370 and 270.
    I have a vendor claiming they have a coax product they've used that would make this installation much easier.  No product link yet to share.  But, obviously, it needs to be able to support 1Gbs and POE+ at our required distances.
    Essentially, it pulls the power and data from the existing POE+ switch and transmits over coax.  The plan is to use either RG-6 (minimum) or RG-11.  Most runs will be between 500-800ft.
    On paper it looks like a great plan.  But... has anyone here tried POE over coax successfully on any scale with this type of outdoor AP?  What bad scenario with this setup should I consider?   Thanks all.
  • 2.  RE: Outdoor AP via coax POE
    Posted Jun 07, 2018 03:48 AM
    Without the company it's hard to know if it's reliable or accurate or not. If it can do 802.3at with 1G you should be fine. I've never seen one though.
