Community Feedback
How is the community doing? Do you have any questions or feedback related for the Airheads Community team? This is the place to let us know.
Outdoor plan in visualrf
  • 1.  Outdoor plan in visualrf
    Posted May 13, 2019 02:53 AM
    Hello all ,
    I have query on how to specify the ap if this is at outdoor/indoor or does it  take byitself after the selection of AP model, because our plan has both roof(Outdoor) and firstfloor(indoor) at same image .
    Incase of openspace how do we specify the height ?
    KIndly assist .
  • 2.  RE: Outdoor plan in visualrf
    MVP EXPERT
    Posted May 13, 2019 04:07 AM
    Have you considered using the Outdoor planner for the outside portion? Within the Outdoor Planner you can specify the AP mounting height.
    https://outdoorplanner.arubanetworks.com/
  • 3.  RE: Outdoor plan in visualrf
    Posted May 13, 2019 06:52 AM
    The following outdoor planner is only for outdoors or we can for indoor plans also  ?
    As our plan has both indoors and outdoor at same floor plan .
    Thanks in Advance
  • 4.  RE: Outdoor plan in visualrf
    MVP EXPERT
    Posted May 13, 2019 07:02 AM
    To do this correctly, you would need another tool such as Ekahau or
    AirMagnet if you wish for a single floor plan. if not split the floor plans
    accordingly.
