Outdoor Planning Tool
  • 1.  Outdoor Planning Tool
    Posted Nov 07, 2013 09:23 AM
    I was wondering if there's any issues with the outdoor planning tool or is anybody experiencing the same issue , I keep getting this everytime I submit the .kmz file:
    I tried different browsers but got the same result.
  • 2.  RE: Outdoor Planning Tool
    Posted Nov 07, 2013 04:52 PM
    Victor,
    Your KMZ has to be configured correctly, with the waypoints in a folder called "Locations".
    Please see my 2 videos on how to use 3DOP  here - http://www.arubanetworks.com/technology/engineer-videos/
  • 3.  RE: Outdoor Planning Tool
    Posted Nov 07, 2013 09:29 PM
    I think I had a similar issues when I was using the tool.  The issue ended up being that my AP names had - (dashes) in them and the tool didn't accept them.  The error message didn't say such, but that was the issue hahaha.
  • 4.  RE: Outdoor Planning Tool
    Posted Nov 08, 2013 11:24 AM
    The location folder is there , I am going to try salvi's suggestion and see if it works
  • 5.  RE: Outdoor Planning Tool
    Posted Nov 08, 2013 06:11 PM
    After removing the dashes I still got the same error.
    I think I am going to start from scratch and give it a try....
  • 6.  RE: Outdoor Planning Tool
    Posted Nov 08, 2013 06:35 PM
    Victor,
    There are two problems with the screen shot you sent.
    The Locations fold must be the top level folder inside the KMZ.  It cannot be in a lower level.
    And the placemarks must be *in* the Locations folder.  In your screenshot, they are outside the folder.
    Hope that helps.
  • 7.  RE: Outdoor Planning Tool
    Posted Nov 08, 2013 06:38 PM
    Ohh I see , let me give that a try.
    Thanks Chuck
  • 8.  RE: Outdoor Planning Tool
    Posted Nov 08, 2013 06:42 PM
    That worked...you are the man...thanks for the help
  • 9.  RE: Outdoor Planning Tool
    Posted Nov 09, 2013 12:12 AM
    Did it work even with the dashes in the AP names?
  • 10.  RE: Outdoor Planning Tool
    Posted Nov 22, 2013 11:08 AM
    Well the dashes were removed already when I moved the APs to the location folder.
    I will try changing the AP names with dashes and see if it still works
