I saw this thread about how to set the username instead of the MAC for mac auth:
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-return-username-MAC-auth/td-p/138541
can something similar be done for other authentication methods, i.e. EAP-PEAP / EAP-TLS? or wont it work there?
I believe a similar process could work although I've never tested it. I know this post and have seen how it works so it would lead me to believe that it might be possible
well i tried and it didn't :) so now im wondering if i do something wrong or if it isnt possible. i can imagine that the proces for dot1x is different and the controller will just not accept it.
any chance anyone else could try?
I just tried it with PEAP and the controller does not show the overridden username.
Going back and thinking a bit, there isn't a IETF "username" in a mac auth SSID so perhaps this cannot be overriden.
