Overwrite Hierarchical Config on MD from MM
  • 1.  Overwrite Hierarchical Config on MD from MM
    Posted Apr 08, 2021 01:41 PM
    Hello All,
    I have a hopefully quick and easy question...  I have an MM setup with quite a few tiers configured
    • Company
      • Region 1
        • Site 1
          • MDs
        • Site 2
          • MDs
        • Region 2
          • Site 3
            • MDs
          • Site 4
            • MDs
          • Region 3
            • Site 5
              • MDs
            • Site 6
              • MDs
            • Site 7
              • MDs
            • Site 8
              • MDs
    I am building EAP-TLS authentication for my org and thus creating new user roles for each scenario to be as granular as possible.  All sites are identical except for Site 8.  So, I build my roles at the Company level, thus pushing my roles out to every controller.  The setting that needs to change at Site 8 is a single user-role ACL.  Naturally, I thought, push out to everything then overwrite at the Site 8 level as I would in our Airwave/iAP setup.  The issue here is, I cannot modify the roles because it was created at a higher level in the hierarchy.
    What options do I have to push this configuration to all sites in as bulk a fashion as possible while being able to overwrite for Site 8?
    1. Use Disaster Recovery and create a local config for that role at the Site 8 level
    2. Preserve the config and pull that single MD out of my /md/company chain so it is in it's own "company" tier
    3. configure per region, then when I get to Region 3, configure per site (least desired option)
    Tips and advise are much welcomes!
    Ian Fritchy
  • 2.  RE: Overwrite Hierarchical Config on MD from MM
    Posted Apr 08, 2021 01:56 PM
    For site 8 , are you planning on failing over APs to any other sites ? if the answer is no, just configure the user-role needed for Site 8 under the Site 8 folder.
    Unfortunately certain settings cant be overwritten at a subfolder level, push all global config from global folder and if theres certain specific config you do it at the folder level.
    Hope this helps.
    Victor Fabian, ACEX#8
    Mobility Architect @ WEI
  • 3.  RE: Overwrite Hierarchical Config on MD from MM
    Posted Apr 08, 2021 03:29 PM
    Thanks, I figured that was the case.  No AP failover so I can create a new role.  Having a second role for Site 8 is what I'm doing today but with all the fun aspects of the EAP-TLS setup, I was hoping to use identical roles and clean up the flow a little bit.
    Appreciate the response!
    Ian Fritchy
