You may have more success posting this question to the
Aruba Instant ON community.
When I look at the configuration, I see for example for TRK2 that on port 49 (sw-a1) there is the vlan configuration and a port speed config; on port 50 it is not.. it may make sense to get that aligned. Different switch types/models/OS behave different on if VLAN config needs to be done on the port, trunk or both. If the switch has a trunk on port 49&50, and if VLANs are missing on port 50, it may be that half of the packets are dropped when the switch tries to load-balance over both connections, but cannot send the packet because of the missing VLAN. To be clear, I don't know how Instant ON exactly behaves, therefor better to check on the dedicated community rather than the Aruba community.
It may also be good to map your interfaces to the diagram, and see if the correct VLANs are set on all ports/trunks, and if you can see port errors (drops, resets, errors, port up/down).
Original Message:
Sent: Jul 25, 2022 09:33 AM
Subject: Packet loss and latency on some devices after replacing previous HP switchs
Hello everyone,
I've replaced two previous HP switchs (1920S 48G 4SFP) by another two HP (1930 48G 4SFP/SFP+), and now I've some odd issues with those, and I really dont know why, but I hope that the Aruba community with more exp than me, can guide me here.
On my previous setup, I was using only one firewall connected to one switch, and each switch was connected by only one ethernet cable. There was only one SFP transceiver in one connected to another secundary cabinet. Before installing this new solution, there was no packet loss's on the device that I've (I've around 25 devices on Switch A1 and around 40 on Switch A2), there was no latency for at least one of the services that my endusers reported having it.
Network diagram:
