Not sure what your issue is... A PAK is a per node license and one is needed for each ClearPass node.
Original Message:
Sent: Dec 10, 2024 05:21 AM
Subject: PAK license key on CPPM
Hi Herman,
I have the issue were we notice that is to PAK key showing under one CPPM node.
Could you please advice me
Original Message:
Sent: Jul 22, 2024 10:48 AM
Herman Sir,
You are a savior !
Original Message:
Sent: Jul 22, 2024 10:09 AM
Assuming the system requirements (memory, disk, CPU, iops) are met, you can just replace the Platform License; click on your appliance under Licensing - Servers; then past in the new platform key.
Original Message:
Sent: Jul 22, 2024 07:09 AM
Dear Experts,
One of our customer was doing PoC.. They ordered CPPM and received the keys. I wanted to know how to install the permanent PAK key on already running VM? or do they need to install the vm again?
