Palo Alto connection
  • 1.  Palo Alto connection
    Posted Jun 08, 2015 03:09 AM
    I've just upgraded a customers pair of 7200 controllers to 6.4.3.1 and the active PAN profile shows the Palo Alto "Down" with nothing sent. A packet capture on the controller showed a failure in the TLSv1 exchange with the certificate - "unknown CA" when I rolled back the code to an earlier 6.4 version it started working again. Anyone any ideas what the issue might be?
  • 2.  RE: Palo Alto connection
    Posted Jun 08, 2015 07:42 AM
    Exactly which earlier 6.4 version did you upgrade from?
  • 3.  RE: Palo Alto connection
    Posted May 11, 2016 09:25 AM
    Hi, we are trying the same, but I can't get my PAN state to show as up? Our instants work perfectly, but our master/local setup not at all. I am pointing the Aruba pan integration to my MGT interface of the PAN. but no logs at all. I recken it has something to do with the certificate and you need to use the hostname instead of the ip address. any help would be appreciated.
