last person joined: 5 hours ago
PaloAlto and CPPM 6.3.1 integration
  • 1.  PaloAlto and CPPM 6.3.1 integration
    Posted Mar 27, 2014 05:05 PM
    Hi all,
    I am trying to integrate Palo and CPPM. Unfortunately CPPM does not send any info to Palo. I see log-in/out at Palo however in the log from CPPM there is no <uid-message> and there are entries as follows:
    [TIME Stamp] WARNING root pactrlmonitprofile Not sending userid object for padevice=[one  of my Palo's interfaces] as the data or auth_token is empty
    It seems that CPPM is misconfigured. Any ideas?
    Many regards,
  • 2.  RE: PaloAlto and CPPM 6.3.1 integration
    Posted Mar 27, 2014 05:09 PM
    Do you follow my TechNote describing the CPPM/PANW integration?
  • 3.  RE: PaloAlto and CPPM 6.3.1 integration
    Posted Mar 27, 2014 05:35 PM
    Absolutely, l did. Additionaly uou did not mention about enabling Userid per zone that is a key. The issue is at CPPM side I guess.
    Many regards,
  • 4.  RE: PaloAlto and CPPM 6.3.1 integration
    Posted Mar 27, 2014 06:31 PM
    OK  - Great, I know you have the basic covered.
    What version of PANW?
    What version of CPPM?
    You don't have multi-vsys do you?
    Nn 'funny' permit/deny rules in PANW stopping CPPM post the data to the PANW node?
    After a user associates to an ssid and you get the auth in CPPM, do you see in the access tracer for the user session an 'Accounting' Tab for the session?
  • 5.  RE: PaloAlto and CPPM 6.3.1 integration
    Posted Mar 27, 2014 08:05 PM
    Now I checked twice and found lack of Accounting at the controller. Now it looks fine! Thanks for tip.
    BTW, it was CPPM 6.3.1, PA-VM-6.0.0 and IAP 4.0.0.4
    Many regards,
  • 6.  RE: PaloAlto and CPPM 6.3.1 integration
    Posted Mar 27, 2014 10:48 PM
    Great to hear..... Pretty sure I have checking the accounting on the Ctrls
  • 7.  RE: PaloAlto and CPPM 6.3.1 integration
    Posted Mar 28, 2014 02:30 PM
    Just wanted to ask.....
    Can you please expand on this "Additionaly uou did not mention about enabling Userid per zone that is a key"....??
    So I can add to my next CPPPM/PANW TechNote update.
    Cheers.
