Cloud Managed Networks
Passpoint supported OS platforms
  • 1.  Passpoint supported OS platforms
    Posted Mar 31, 2023 10:32 AM
    Dear All,
    What are the minimum OS versions that Passpoint is supported in Windows,MacOS,Linux,Android OS and iOS ?
    Thank you
  • 2.  RE: Passpoint supported OS platforms
    Posted Apr 04, 2023 10:37 AM
    I think it has to do with chipsets/components/drivers rather than pure OS Version. You can check certified products here. Passpoint is around for quite some time.
    How do you want to deploy Passpoint?
  • 3.  RE: Passpoint supported OS platforms
    Posted Apr 04, 2023 10:50 AM
    Dear Herman,
    Thank you,
    As per my knowledge for after Aruba Central was synced with Azure AD, the devices connected to the SSID authenticating with Azure AD need to support Passpoint.That is why i am checking about it. If i am wrong please correct me
  • 4.  RE: Passpoint supported OS platforms
    Posted Apr 04, 2023 11:51 AM
    Ok, Passpoint is something different than Cloud Authentication and Policy, which I think is what you refer to by 'Aruba Central was synced with Azure AD'.
    For Cloud Authentication and policy, check the supported devices and versions here.
