Network Management
Password Change on Airwave and corntrollers
  • 1.  Password Change on Airwave and corntrollers
    Posted Feb 29, 2012 07:53 PM
    So we went through a password change the other day on our network systems.
    I changed the "admin" and "root" passwords on the AMP and on the controllers.  Changed the settings in Airwave or the ARUBA creditials under Device Setup - Communication.
    All the APs and controllerscame in with an error relative to failed telnet/ssh credentials.
    Set everything back and it works great - errors are gone after doing an audit on the devices from Airwave.
    Is there a specific process to follow for password change?
    I checked and double-checked all the creditials, feel like I missed something somewhere?
  • 2.  RE: Password Change on Airwave and corntrollers
    Posted Feb 29, 2012 08:47 PM
    Did you set the new credentials on the AP Manage page for the controllers in question?
    Device Setup->Communication is not use for normal communication with the controllers.  It's used in discovering devices and as a default when the device is added.  The credentials on the AP Manage page are the ones actually used in communicating with devices.
  • 3.  RE: Password Change on Airwave and corntrollers
    Posted Mar 01, 2012 05:30 AM
    I did.
    Thanks.
  • 4.  RE: Password Change on Airwave and corntrollers
    Posted Nov 22, 2018 04:22 PM
    In addition,
    I would like to change the local admin password in the AMP and all the AP's that are discovered by the AMP.   Is there a feature or step to follow in order to change the local admin of the AP's but not doing it one AP at a time?
