last person joined: 11 hours ago
password instant - airwave
  • 1.  password instant - airwave
    Posted Mar 23, 2016 12:45 PM
    Hi everyone
    Is it possible know o change password of instant from the airwave ?
  • 2.  RE: password instant - airwave
    Posted Mar 23, 2016 07:15 PM
    sure
    You can set nearly anything in the configuration from Airwave. Can you elaborate on your set up and maybe we can tell you haw to make the change you want.
  • 3.  RE: password instant - airwave
    Posted Mar 28, 2016 10:02 AM
    Hi
    My problem is the next, I have a Airwave in which for the moment, 14 instant reported, I need standardize  credentials the all instant, ¿it´s possible change of instant password since airwave?.
    all instant are formed by 1 IAP 275 and 2 RAP 155
    *there is a instant that I dont configure, and I dont which are the credentials with which was configured,   I dont want to do a factory reset, I want to change the credentials from the airwave, ¿is this possible?
    Thanks for your help
  • 4.  RE: password instant - airwave
    Posted Mar 28, 2016 10:06 AM
    If you are using IGC (Instant Graphical Configuration), you can add an admin user:
