Aruba Apps
Password Recovery for Aruba 7010 Controller
This thread has been viewed 31 times
  • 1.  Password Recovery for Aruba 7010 Controller
    Posted Dec 15, 2023 08:27 AM
    I've been asked to help with management of an Aruba network at a church.   While I have a lot of networking background, I've never used Aruba before.   Nobody knows what the admin password is (the person that set it all up is gone).  The front panel on the controller says that it running 8.5 software.
    I was able to make a USB console connection today and I thought I was home free on the password reset procedure.  Unfortunately, that was not the case.
    User: password
    Password:
    (XXXX) *#configure terminal
    This controller is managed by a Mobility Master.
    Configuration changes can only be performed on the Mobility Master.
    (XXXX) *#mgmt-user admin root
    Invalid input detected at '^' marker.
    I tried local-config enable and disaster-recovery on
    (XXXX) *#local-config enable
    (XXXX) *#disaster-recovery on
    Error:You do not have permission to execute this command
    Anyone have any ideas of things to try?   TIA!
  • 2.  RE: Password Recovery for Aruba 7010 Controller
    Posted Dec 15, 2023 08:29 AM
    This controller is managed by a Mobility Conductor (previously named MM). You would need to change the password from there.
  • 3.  RE: Password Recovery for Aruba 7010 Controller
    Posted Dec 15, 2023 08:40 AM
    Ok, I appreciate the reply and your patience with my ignorance...
    Is this Mobility Conductor (formerly MM) a cloud based thing?  Or a separate piece of hardware located on site somewhere?   If hardware, is there a certain model number(or numbers) that I'm looking for)??
  • 4.  RE: Password Recovery for Aruba 7010 Controller
    Posted Dec 15, 2023 09:18 AM
    Edited by VanD Dec 15, 2023 10:11 AM
    It can be a VM or aruba hardware
    Aruba Mobility Conductor Controller data sheet (arubanetworks.com)
  • 5.  RE: Password Recovery for Aruba 7010 Controller
    Posted Dec 15, 2023 10:08 AM
    Thanks.   So the 7010 that I was trying to get into is NOT the controller?
  • 6.  RE: Password Recovery for Aruba 7010 Controller
    Posted Dec 15, 2023 10:12 AM
    It is a controller , but it is managed by a Mobility conductor/ Master
  • 7.  RE: Password Recovery for Aruba 7010 Controller
    Posted Dec 15, 2023 10:23 AM
    Thank you.   That is helpful.
    I haven't noticed any other Aruba hardware other than the 7010 controller and some switches.   I will go on another hunt around the building.
    I'll also look for the potential that it's running on a VM somewhere.
  • 8.  RE: Password Recovery for Aruba 7010 Controller
    Posted Dec 15, 2023 11:29 AM
    it could also be at the datacenter or any other remote location
  • 9.  RE: Password Recovery for Aruba 7010 Controller
    Posted Dec 15, 2023 11:35 AM
    Yeah, I'm starting to think that is the case - some service provider set this up and is managing remotely.
    If so, any tricks to figure out who it is?
  • 10.  RE: Password Recovery for Aruba 7010 Controller
    Posted Dec 18, 2023 07:32 AM
    if you are on the controller you can do a "encypt disable" and after that a "show run"
    On the first lines of the config you can see the "conductorip" This is the Mobility Master or Conductor.
    If it is correctly configured you should also find a line with "location" there.
    regards
    Markus
