Comware
last person joined: 7 days ago
Password Recovery HPE 5130 (Two Switch IRF Cluster)
  • 1.  Password Recovery HPE 5130 (Two Switch IRF Cluster)
    Posted Jul 06, 2022 02:05 PM
    Hi Guys,
    I need to recover password of HPE 5130 Comware switch within the IRF cluster. Can anyone suggest safest and easiest way to do that.
    DhanushkaH
    DhanushkaH
  • 2.  RE: Password Recovery HPE 5130 (Two Switch IRF Cluster)
    Posted Jul 07, 2022 03:16 AM
    Hello DhanushkaH,
    Please check the following link:
    Support Center
    Hpe remove preview
    Support Center
    View this on Hpe >
    P.S. Maybe it is good idea to shut down the secondary switch and work on the primary switch with password recovery. Also as the startup config maybe saved without secodary switch config setting when loaded after restart it is good to have display the startup before doing any modification and copy the configuration with the settings of the ports on the secondary switch to preserve it. When the configuration is saved with only one switch may load the config without settings for the missing switch as it is new boot without IRF.
    Hope this helps!
    -Alex-
  • 3.  RE: Password Recovery HPE 5130 (Two Switch IRF Cluster)
    Posted Jul 07, 2022 03:28 AM
    Thanks Alex
    This is very helpful. But how can I do this process within the IRF Cluster ? Can we do that follow up this process or need to follow another method
  • 4.  RE: Password Recovery HPE 5130 (Two Switch IRF Cluster)
    Posted Jul 07, 2022 03:44 AM
    Hello DhanushkaH,
    It is important to check the config before saving it and verify if the saved configuration has all interfaces from both devices.
    If not you can copy and then paste the config of the ports of the secondary switch when you rebuild the IRF.
    In any case you need the full configuration copy with both devices to restore if needed.
    Hope this helps!
    -Alex-
  • 5.  RE: Password Recovery HPE 5130 (Two Switch IRF Cluster)
    Posted Jul 08, 2022 02:40 AM
    Thank you very much Alex..........!
