last person joined: 4 hours ago
password recovery on RAP 3
  • 1.  password recovery on RAP 3
    Posted May 03, 2013 06:26 AM
    Hi everyone!
    I have a big problem on my RAP3, I can't reset the access point  (instant mode) by the push button, the RAP reboot but don't reset...
    I want to reset it because I don't have any access to the webui because I can't find the login/password.
    I saw that on CLI there is the login/password : password/forgetme! but, as you know, there isn't CLI interface on this RAP so...
    Someone knows a way to reset the password ?
    Thanks guys!
  • 2.  RE: password recovery on RAP 3
    Posted May 03, 2013 08:57 AM
    Sometimes this could a pain in the ....
    What I usually do is that when I start to press the reset button I remove the power from the RAP3 while pressing the reset button then put the power back and keep pressing the reset button for at least 5/7 seconds.
    Also make sure that you don't have the RAP3-A you are trying to reset connected to the same IP segment you have another RAP3-B configured otherwise it will get the config from that one.
