Paste CLI Config
  • 1.  Paste CLI Config
    Posted Jul 16, 2019 02:00 PM
    I must be missing something, is there a proper way to copy and paste CLI config into an IAP? If I just take a config and paste it into the CLI, it doesn't seem to be smart enough to identify new sections. I have to 'exit' out of each section before it will start a new one.
    For instance, trying to paste in two ssid-profiles. It will finish the first one, but instead of going into the second one it will show a parse error.
    Thanks.
    IAP (config) # wlan ssid-profile Survey-5Ghz
    IAP (SSID Profile "Survey-5Ghz") #  enable
    IAP (SSID Profile "Survey-5Ghz") #  type employee
    IAP (SSID Profile "Survey-5Ghz") #  essid Survey-5Ghz
    IAP (SSID Profile "Survey-5Ghz") #  opmode opensystem
    IAP (SSID Profile "Survey-5Ghz") #  max-authentication-failures 0
    IAP (SSID Profile "Survey-5Ghz") #  vlan guest
    IAP (SSID Profile "Survey-5Ghz") #  rf-band 5.0
    IAP (SSID Profile "Survey-5Ghz") #  captive-portal disable
    IAP (SSID Profile "Survey-5Ghz") #  dtim-period 1
    IAP (SSID Profile "Survey-5Ghz") #  broadcast-filter arp
    IAP (SSID Profile "Survey-5Ghz") #  dmo-channel-utilization-threshold 90
    IAP (SSID Profile "Survey-5Ghz") #  local-probe-req-thresh 0
    IAP (SSID Profile "Survey-5Ghz") #  max-clients-threshold 64
    IAP (SSID Profile "Survey-5Ghz") # wlan ssid-profile Survey-2.4GHz
    % Parse error
  • 2.  RE: Paste CLI Config
    Posted Jul 16, 2019 02:48 PM
    Try to adding "exist"
    exit
  • 3.  RE: Paste CLI Config
    Posted Jul 16, 2019 03:06 PM
    Yeah, adding 'exit' to each section works, but if i'm pasting in a whole config I have to go through it first and add 'exit' a whole bunch of times? Also it seems like there are some cases where 'exit' is not needed and it disconnects you from the AP, that is annoying also.
