Patch install ClearPass
  • 1.  Patch install ClearPass
    Posted Dec 06, 2013 04:03 AM
    I want to install patch bundle 3 on our ClearPass evaluation system. The download and install of the patch software via ClearPass gives an install error.
    Installing patch
    from=CPPM-x86_64-20131022-clearpass-6.2-updates-3-patch.bin
    Extracting
    patch...
    Preparing...
    package clearpass-guest-plugin-kernel-6.2.3-29032.noarch is already installed
    INFO:
    Preparing ...
    INFO: Running pre-install scripts ...
    INFO: Applying patch
    ERROR: Applying the patch failed, aborting: RPM upgrade failed
    Exiting
    with 255
    So I downloaded the file offline without any problem but when I start the import of the patch I get an error message 'Content-type "text/plain" is not supported'.
    Why I can't import the file? Is this due the the signed file? I can't unzip the file to a bin file. Install via CLI ??
  • 2.  RE: Patch install ClearPass
    Posted Dec 06, 2013 04:06 AM
    Did you try using a different browser?
  • 3.  RE: Patch install ClearPass
    Posted Dec 06, 2013 04:17 AM
    I first tried with IE, a second test with Chrome gives:
    Upload is not compatible: update is already installed or is a lower version than one on the system
    I already have cumulative patch 2 installed and patch 3 with an install error. The previous patch 3 installation iwith install error s seeen by the import process.
    Any idea?
  • 4.  RE: Patch install ClearPass
    Posted Dec 06, 2013 04:22 AM
    Try rebooting and run the install.
    Can you download and run the install from the update page?
    If not try running it from the cli
    1. Begin the upgrade process by typing the following command:
    system upgrade
    For example: system upgrade CPPM-upgradeimage.bin
    The upgrade process should begin immediately upon executing the above command.
    2. After the upgrade is complete, restart the machine using the following CLI command
    system restart
    The ClearPass Policy Manager will restart and boot up to the latest version, CPPM 6.1.
  • 5.  RE: Patch install ClearPass
    Posted Dec 06, 2013 06:38 AM
    Hi Troy,
    problem is that I'm not able to import the patch-file via the GUI (and place the file on the CP server somewhere in a directory). Do you know where to place the file on the CP server via CLI? After that I can run the system upgrade .... command as you proposed.
  • 6.  RE: Patch install ClearPass
    Posted Dec 06, 2013 06:41 AM
    You can host it locally HTTP or tftp an run the
    "system update -i http://address.com/filename.bin"
  • 7.  RE: Patch install ClearPass
    Posted Dec 06, 2013 06:51 AM
    Troy,
    How can I convert the patch-file with extension 'zip.signed' to a normal zip file where I can unzip the bin-file from
  • 8.  RE: Patch install ClearPass
    Posted Dec 06, 2013 07:00 AM
    You shouldnt have to. The system will extract the file.
  • 9.  RE: Patch install ClearPass
    Posted Dec 06, 2013 07:17 AM
    Due to firewal policy i'm not able to do http or SSH. Seems that CP is only supporting HTTP and SSH.
    system upgrade user@hostname:/<filename> [-l] [-L]     (uses SSH to connect)
    system upgrade http://hostname/<filename> [-l] [-L]
    system upgrade <filename> [-l] [-L]
     -l   -- restore last 1 week of access tracker records after upgrade
    -L   -- do not restore any access tracker records from this version
    I'll ask the VMware colleagues to copy the file on the server. Do you know in which directory the file has to be copied? So I can use the system upgrade command for a local file on the system (3th in list above)
    Thx.
    Patrick.
  • 10.  RE: Patch install ClearPass
    Posted Dec 06, 2013 07:23 AM
    That is unsupported. You will have to open a TAC case and have them work with you to upgrade. We only support file transfer from the command line, gui import or with the auto download.
    The easiest would be to grant cppm Internet access and let it auto download the file.
  • 11.  RE: Patch install ClearPass
    Posted Dec 06, 2013 07:33 AM
    Troy,
    CPPM has access to internet but apparently only downloaded a part of the patch-file (compaired file size). This generated the install error in the GUI. I cannot remove this from the system through the GUI. The install error stays displayed in the GUI.
    But, I'll contact TAC for support.
    Thx for your efforts and help.
    Patrick.
  • 12.  RE: Patch install ClearPass
    Posted Dec 06, 2013 07:50 AM
    Ok, I'll open a TAC case to solve the problem.
    Patrick.
  • 13.  RE: Patch install ClearPass
    Posted Apr 29, 2014 03:55 AM
