Hi @julien-tahiti
Please refer the below notes:
Redundant power supply
Load-sharing redundant power supplies
J9828A, max 630 W, system power (12V), 275 W of POE power;
J9829A, 630 W max system (12 ) power, 900 W max POE power;
J9830A, 630 W max, system (12V) power, 2500W max POE power
The above Power supplies can be installed in the back of the 5400R zl2 switches. To provide redundancy, each power supply should be connected to different AC power sources. Then, if one AC power source fails, the switch will continue to run.
Any combination of J9828A, J9829A and J9830A power supplies can be used in the same switch. However, HPE recommends to only use like supplies in a unit for more deterministic behavior in event of a power supply failure.The switch redundant power supply is hot swappable, but, as indicated by the caution statement on the power supply, it must be disconnected from AC power before being installed or removed.
Because the switch can run on a single supply, removing a redundant supply will not interrupt switch operation. However, with a single power supply system will power on Interface module up to 630W. The rest of the Interface modules are powered on the priority of the slot. The slot A has the highest priority and the slot L has the lowest priority.
When power is restored from a second (or more) power supplies, a system reload or interface module reset is not required to restore operation to slots G-L. The 5400R modules will restart by themselves when power recovers.
Reference: https://support.hpe.com/hpesc/public/docDisplay?docId=c04344557&docLocale=en_US
Since you have PoE+ modules, its good to refer the below document (Page 118 onwards)
https://support.hpe.com/hpesc/public/docDisplay?docId=c04344559
