PBR - AOS8.3
  • 1.  PBR - AOS8.3
    Posted Jun 12, 2018 02:57 PM
    Hi All,
    I would like that users wired from VLAN 42 (natted) access the internet by VLAN 41 instead VLAN 1. Please see the diagram attached.
    The VLAN 42 is assigned port 0/2 and the VLAN 41 is assigned at port 0/5 of my controller runnung AOS 8.3
    Could you tell me if is this configuration possible?
    Thank you
  • 2.  RE: PBR - AOS8.3
    Posted Jun 12, 2018 03:32 PM
    Unchecked the nat inside at the vlan level and do it under the user-role
    And then create an ip nat pool using the IP address you want to use and then create an access rule to nat everything via the NAT pool
    Sent from Mail for Windows 10
  • 3.  RE: PBR - AOS8.3
    Posted Jun 12, 2018 04:17 PM
    Hi Victor.
    Thank you for the tip.
    I create the NAT Pool as showed at pic1.
    But when I went to create the user policy the a port option was required.
    1. How could I choose all ports?
    2. The Pic 3. Is it the rigth way to associate policy to the controller interface?
    Thank you very much
  • 4.  RE: PBR - AOS8.3
    Posted Jun 13, 2018 04:52 PM
    Try adding the ACL for the NAT pool via CLI
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
