PBR per SSID
  • 1.  PBR per SSID
    Posted Mar 16, 2017 03:58 PM
    Hello All,
    I have a Controller with 3 SSID in tunnel mode.
    I need that each SSID go to a different default gateway.
    It's possible to do it using PBR? Each SSID are a differnet network. Can I create a rule to forward the traffic basead on Wireless user network?
    Paulo R.
  • 2.  RE: PBR per SSID
    Posted Mar 16, 2017 06:02 PM
    Hi Paulo,
    Can you give us more information on what you are trying to achieve?
    I understood that you have 3 SSIDs - 3 subnets. Is your controller acting as L3 or L2? If it is L2 you could have different VRF's on the router/switch and each one will have it's own routing table, hence different default gateway.
    Again, with more information probably more help could be given.
    Borja
  • 3.  RE: PBR per SSID
    Posted Mar 17, 2017 03:28 AM
    Hey!
    If you just want them to end up on different VLANs that´s super easy to configure either in the Virtual AP profile of each SSID or on the role that the AAA profile places the users in.
    Cheers,
  • 4.  RE: PBR per SSID
    Posted Mar 17, 2017 04:19 AM
    Hi Christoffer,
    yes, you are right! If he only needs default gateway it is as easy as you said.
    Not sure why I thought he wanted a default route for each SSID (subnet) - I guess that the Policy Based Routing made me think that!!
    Anyways, thanks
    regards
    Borja
  • 5.  RE: PBR per SSID
    Posted Mar 17, 2017 07:20 AM
    Let me explain better my case:
    We have a shared infrastructure that need 3 different access (3 different companys).
    On the Access Point, I can delivery only 1 VLAN. So, the AP will use this VLAN to get IP address and communicate with the Controller.
    On Controller side, I have 4 different VLANs (trunk).
    VLAN A: Communicate with Access Points
    VLAN B: Company 1
    VLAN C: Company 2
    VLAN D: Company 3
    VLAN A will tunnel all the traffic to Controller.
    VLAN B,C and D has your own DHCP Server and default Gateway above the Controller.
    What I need:
    3 SSID (company 1,2,3) and route each SSID to a different Default Gateway.
    How is the best way to archive it? Create a PBR? Using L2 (the Access Point has only 1 VLAN) ?
    Thank you,
    Paulo R.
  • 6.  RE: PBR per SSID
    MVP EXPERT
    Posted Mar 17, 2017 07:34 AM
    The client will take the default gateway assigned to them via DHCP. Whatever is the default gateway for the client, that will do your routing between VLAN's.
