PC cannot see particular SSID
  • 1.  PC cannot see particular SSID
    Posted Sep 16, 2015 06:32 AM
    Hi ,
    PC cannot see particular SSID and it see only a channel  in an area
    What could be the problems , is it a design issue
    Thank you
  • 2.  RE: PC cannot see particular SSID
    Posted Sep 16, 2015 06:34 AM
    Is your SSID configured for a certain band (2.4 vs 5) instead of both?
    Tim
  • 3.  RE: PC cannot see particular SSID
    Posted Sep 16, 2015 07:30 AM
    configured both , other area i am able to connect
  • 4.  RE: PC cannot see particular SSID
    Posted Sep 16, 2015 07:33 AM
    What AP model? Are these APs in a different group with an AM or SM config?
    Tim
  • 5.  RE: PC cannot see particular SSID
    Posted Sep 16, 2015 09:36 AM
    Mostly this issue is because of AM mode, check whether the AP is on AP mode or AM mode. if it is on AM mode, it will not broadcast SSID, sometimes ARM will convert AP into AM mode while fine tuning the spectrum.
    you can check the same by using "show ap databse "
  • 6.  RE: PC cannot see particular SSID
    Posted Sep 16, 2015 09:38 AM
  • 7.  RE: PC cannot see particular SSID
    Posted Sep 16, 2015 11:18 AM
    What model of AP is it?  Some older models were single radio only.
